Jul 17th, 2024, 6:34am
help needed in opamp design (Read 2075 times)
rampat
May 13th, 2010, 8:58pm
Hi All,
I have opamp spec as follows
Adc=100dB,UGB=900MHz,Supply=1.2V ,Tech=0.13u CMOS
I have 1.2V MOS devices with vthn=vthp~0.45V in this process
Could someone help me in deciding the architecture of opamp  for above specs ?
thanks
View Profile rampat   IP Logged
raja.cedt
Re: help needed in opamp design
Reply #1 - May 14th, 2010, 1:45am
hi,
   seems tough spec..but try to use two stage with cascode in the first stage and use some feed forward kind of compensation rather than splitting poles....  better you do the open loop and please publish pole zero location, then people may suggest some tech.
Rajasekhar.
Mayank
Reply #2 - May 20th, 2010, 7:07pm
Hi
900MHz is a bit more than usual which means you gotta employ some wideband Amplifier techniques...
Refer Allen Hollberg or some papers.
Mayank
