Jul 18th, 2024, 11:23pm
Design issues for IOS technique (Read 3967 times)
Parveen
Indore
Jul 10th, 2010, 12:15am
In the input offset storage technique in comparators for offset cancellation, there are capacitors at the inputs of the comparator. While designing a comparator for the same, how can we maintain our dc bias voltage at the gates of the input transistors, with capacitors placed at the gates??
raja.cedt
Re: Design issues for IOS technique
Reply #1 - Jul 11th, 2010, 9:38am
hi..could you please explain bit clear....
Rajasekhar
Parveen
Indore
Reply #2 - Jul 11th, 2010, 10:04am
Re: In designing a comparator with input offset cancellation technique, we need to design switches. There are three switches: one connecting the input to output(unity gain feedback), second connecting the input to reference voltage and third connecting to the inputs to be compared.
Out of these three the first is placed to the right plate of the capacitor and the other two to the left of the capacitor near the inputs.
While designing the amplifier we do the dc analysis and adjust the dc voltages. After obtaining these values, when a capacitor is introduced at the inputs, as soon as the switch for the feedback is connected, due to some leakage current through the switch(transmission gate), the capacitor acquires some charge at the right plate near inputs and settles on to that dc value changing the operating points.
How should I avoid these leakage currents????
Lex
Eindhoven, Holland
Reply #3 - Jul 12th, 2010, 1:06am
You could use a T-switch driven by some break-before-make circuit?
Assuming that the input transistor is not the dominant factor, of course Wink
AnalogDE
Reply #4 - Jul 12th, 2010, 11:06am
This is charge injection -- I wouldn't call it "leakage current".  The switches turning on/off dump charge into the inputs of your comparator.
You can reduce the effect of this by
1)  using smaller switches
2)  larger input capacitor
3)  larger input devices in your comparator
HdrChopper
Reply #5 - Jul 15th, 2010, 5:45pm
In adittion to what AnalogDE propsed, if further charge injection reduction is required you could adjust the clocks driving your switches to have constant VGS with a charge pump circuit.
Obviously that makes the circuit more complex.
Best
Tosei
Keep it simple
