Apr 28th, 2024, 5:01am
The effect of the noise shaping of the loop (Read 6769 times)
supermoment
Aug 02nd, 2010, 6:30am
The effect of the noise shaping of the loop can be observed in this spectrum (refer to the diagram)
What does the "noise shaping of the loop" refer to?  Does it refer to region #2 in the diagram?
I know that  the clk freq can be shaped by loop filter shape in the PLL.
Could we tell the loop BW from this noise shaping effect?
ACWWong
Oxford, UK
Re: The effect of the noise shaping of the loop
Reply #1 - Aug 2nd, 2010, 2:49pm
Indeed the "noise shaping of the loop" could mean the the loop filter shape, but this terminology can also be used to refer to other things in the PLL (depending on the circumstances/architecture of the PLL....)
Anyway in your case its the loop BW is about 10MHz (roughly the width of the plateau at 2). The hump at 2 and roll-off between 2 and 3 is due to the net loop filter response. Levelling-off at 3 could be due to wideband noise of PLL signal (e.g. due to buffers etc.), but also analyser noise floor.
hope this helps... for more information on PLL loop dynamics, Dean Banerjee from National semiconductor writes good application notes. Google him!
cheers
aw
supermoment
Reply #2 - Aug 2nd, 2010, 8:58pm
thx for your reply to confirm my understanding.
Since the loop BW can be observed from the spectrum, we could also see the overshoot response. The little hump there indicates the overshoot.
am I  right?
Mayank
Reply #3 - Aug 3rd, 2010, 4:47am
am I  right?
Wrong.
Judging PLL XF from PLL Phase noise plot could be tricky.
The peaking that you see in phase noise plot in region 2 could be from either osc. phase noise dominating due to low BW, or i/p jitter peaking due to peaking in XF or BOTH.
Hence, to obtain loop response params, simulate loop characterstics for PLL XF separately, instead of judging them from PLL phase noise plot.
Mayank.
supermoment
Reply #4 - Aug 3rd, 2010, 5:22am
I am aware that it is tricky.
But it helps in the silicon debug or measurement to give rough idea on the PLL BW & response.
I could extract the close loop response from transient analysis.
BTW, I still do not know how to obtain PLL transfer function. Do you know?
love_analog
Reply #5 - Aug 7th, 2010, 1:23pm
you cannot easily obtain PLL Xfunction from the spectrum analyzer. What you can do is compare your measurement with sims and vary the sim parameters to make it match measuremnts. This will at least give you an idea of what could be off in your sims.
loveanalog.blogspot.com
The Power of Analog
SSA@A
Reply #6 - Jun 13th, 2011, 9:22pm
FYI.
Though this is not the answer for your question....
General topics on PLL design and measurement is discussing on this application note.
"Boosting PLL Design Efficiency From free-running VCO characterizations to closed-loop PLL evaluations"
http://cp.literature.agilent.com/litweb/pdf/5989-9848EN.pdf
here's a solution for your PLL design.
http://www.agilent.com/find/ssa
