Turin wrote on Aug 30th, 2010, 3:19am:I'm trying to simulate a simple passive circuit (lowpass eliptical filter)
but i don't seem to get that right result in the simulation.
Before using simulator, can you understand filter theory correctly ?
Cutoff frequency of your LPF is 1Hz, isn't it.
However you set start frequency of AC analysis as 1kHz.
Set AC analysis like followings.
Start=0.01Hz
Stop=10KHz
Log Sweep=21pts/dec
Set x-axis as logscale in graph plot
Turin wrote on Aug 30th, 2010, 3:19am:Also irrelevant to the first question can someone explain in the ideal OpAmp in the ADS2004 library what does pins 4 and 5 are for nad how are they used?(last pic)
What on earth do you mean by "
nad" ?
See
http://edocs.soco.agilent.com/display/ads2009/OpAmpIdeal+%28Ideal+Operational+Am...It is very clear for meaning of pin-4 and pin-5.
BTW, why don't you use following ?
http://edocs.soco.agilent.com/display/ads2009/OpAmp+%28Operational+Amplifier%29
