May 15th, 2024, 5:14am
For anypne tha has any experience on ads... (Read 4504 times)
Turin
Greece
Aug 30th, 2010, 3:19am
I'm trying to simulate a simple passive circuit (lowpass eliptical filter) but i don't seem to get that right result in the simulation.I tried some thing but still it does not seem to work. I'm just asking if anyone here see sth that i'm missing and don't do right.
Uploaded with ImageShack.us
Also irrelevant to the first question can someone explain in the ideal OpAmp in the ADS2004 library what does pins 4 and 5 are for nad how are they used?(last pic)
Re: For anypne tha has any experience on ads...
Reply #1 - Aug 30th, 2010, 4:39am
Turin wrote on Aug 30th, 2010, 3:19am:
Before using simulator, can you understand filter theory correctly ?
Cutoff frequency of your LPF is 1Hz, isn't it.
However you set start frequency of AC analysis as 1kHz.
Set AC analysis like followings.
 Start=0.01Hz
 Stop=10KHz
 Log Sweep=21pts/dec
Set x-axis as logscale in graph plot
What on earth do you mean by "nad" ?
See http://edocs.soco.agilent.com/display/ads2009/OpAmpIdeal+%28Ideal+Operational+Am...
It is very clear for meaning of pin-4 and pin-5.
BTW, why don't you use following ?
http://edocs.soco.agilent.com/display/ads2009/OpAmp+%28Operational+Amplifier%29
« Last Edit: Aug 30th, 2010, 8:52am by pancho_hideboo »
Turin
Greece
Reply #2 - Aug 31st, 2010, 2:54am
Actually the filter is 1Mhz...At least according to the book I took the parameters from.
And the nad is a typo...I mean and....
I Want to use an ideal opamp to do some comparisons....
Thanks man...
Reply #3 - Aug 31st, 2010, 5:52am
Turin wrote on Aug 31st, 2010, 2:54am:
It can never be fc=1MHz.
Surely consider values of L and C in your filter.
For example, L=0.8255H, C=0.399F for parallel LC tank in your filter.
So attenuation pole frequency is located around f0=1/(2*pi*sqrt(L*C))=0.277Hz.
I think cutoff frequency of your LPF is 1/(2*pi)=0.16Hz.
See attached figure.
Transfer function of your filter circuit shows LPF charactereristics with attenuation pole at 0.268Hz actually.
Before using simulator, learn very very very very very very very very basic theory of filter circuits surely.
« Last Edit: Sep 1st, 2010, 3:53am by pancho_hideboo »
Reply #4 - Sep 2nd, 2010, 8:15am
Attached figure is a comparison between Hv(Conventional Voltage Transfer Function) and S21.
You have to use S21 for characterization of LC filter.
Turin
Greece
Reply #5 - Sep 8th, 2010, 9:42am
Thanks for the help!
