Aug 16th, 2024, 9:32pm
Probe node voltage in one subckt (Read 2085 times)
Sep 15th, 2010, 6:13pm
Hi Guys,
How do I probe ALL node voltage in one specified subckt when I run simulation with spectre in ADE? I mean all nodes in an arbitrary specified subckt.
Yawei
Re: Probe node voltage in one subckt
Reply #1 - Jan 2nd, 2011, 9:29am
Hi Yawei,
There's an example of doing this in the "spectre -h save" :
save * subckt=inv
(where inv is the name of your subckt master). Note you have to do this via an include file (e.g. including a *.scs file using this syntax, via the Model Libraries form); there's no way of defining it directly in the ADE UI. Partly that's due to the challenges of translating wildcards between different namespaces, but hopefully we can resolve that one day!
