May 20th, 2024, 6:22pm
bind Error w/t System Verilog Assertion to AMS (Read 3294 times)
sand_dolphin2
Japan
Oct 07th, 2010, 2:18am
Now , i'm using Cadence's  AMS Designer.
DUT was made by schema.
Modules of Test bench were made by Verilog-D or AMS.
TOP block of Test bench was made by schema.
So, i try to add System Verilog Assersion to Test Bench.
And so, i have one problem which are depending on
w/ or w/o bind function on System Verilog.
1) making System Verilog code w/o bind
No Error on compiling and runs well that assersion
like this
   property pr_001; @(posedge TESTBENCHTOP.I13.a)
       !TESTBENCHTOP.I13.b |=> TESTBENCHTOP.I11.D8out == 8'h00 ;
   endproperty
2) making Sytem Verilog code w/t bind
Error occured on compilation
like this bind function of System Verilog
bind TESTBENCHTOP sva_monitor sva_monitor(
   .CLK(I13.a),
   .RST_X(I13.b),
   .DOUT(I11.c)
anybody, plz let me know how to the best way for..
Sad
sand_dolphin2
Japan
Re: bind Error w/t System Verilog Assertion to AMS
Reply #1 - Oct 12th, 2010, 11:02pm
Cadence Japan let me know
there is possibility this caused by tool's bug.
for avoid this problem, Cadence japan advice bellow 2 cases
1) order reading sva,vams
not reading bind function before vams
2) on sva file
should be write bind first,
 before module function which include assertions
easy way is 2),
Now i success for using SVA bind function on AMS Designer
anyway i'll let u know correct report from Cadence R&D
thx
Wink
