May 18th, 2024, 7:16pm
multiplexer (Read 1862 times)
hieuphong
vietnam
multiplexer
Oct 26th, 2010, 6:26pm
Hi you! I need to help
I have a circuirt  Wilkinson power divider four gates
It is only one input but 4 outputs with:
First Output  will change from 0 degree to 90 degree
Second Output  will change from 90 degree to 180 degree
Third Output  will change from 280 degree to 270 degree
Fourth Output  will change from 270 degree to 360 degree
But when I want to measure out at output I have to change device-display four times
Now, I want “ I don’t need to change device-display I still measure out signal at output from 0 degree to 360 degree “
My opinion : I will use a multicomplexer at output then we can measere continuously with a output. But I don’t know how to do
Who can help me?
nothing is impossible
View Profile WWW hieu.phong   IP Logged
hieuphong
vietnam
Re: multiplexer
Reply #1 - Nov 9th, 2010, 3:04pm
maybe, it is very diffilcult to find a MUX. Now, i want to find a switch to change among four outputs... Who can suggest me??? ( it is a switch with four inputs and one ouput)
Re: multiplexer
Reply #2 - Nov 10th, 2010, 5:34am
What kind of a switch do you want?  Will you set the mux by parameters, changing the parameters for a different sim?  Or does the mux need to switch during the simulation, based on other signals?
Do you want a transistor-level switch, or an ideal one?
You really haven't given us enough to work with, and you haven't shown us that you're putting in some effort yourself and not just expecting us to solve all your problems for you.
hieuphong
vietnam
Re: multiplexer
Reply #3 - Nov 10th, 2010, 3:26pm
Thanhks for reading...
My problem:  To design a phaseshift from 0 to 360 degree... it users microstrip technology
My idea: i have designed include 2 part
part one: i desgined a Hybrid 90  degree phase shift that uses varactor to control phase at output. But It changes from 0 to 90 degree So..
Part two: I desgned a power divider. I uses wilkilson  power splitte one input and four outputs....
My question:. I want to find a switch  that has 4 inputs and one output to couple with Wilkilson power spliter....
I have used ADS software to desgin
hieuphong
vietnam
Re: multiplexer
Reply #4 - Nov 10th, 2010, 11:13pm
+) What do you mean by "device-display" ?
it is  scope to observe
+) What do you men by "multicomplexer " ?
i'm sorry for incorect my words, it is multiplex
Hi pancho
OK, I will explaint clearly
My problem:
I have to design a shift phase 360 degree at 915MHZ by microstrip technology.
My solution
I use a Hybrid 90 degree and fours ways Wilkilson power sipliter. Then, I will  connect them together to satisfy my problem.
I have simulated it by ADS software… You can see it is over there
But I have met  with difficult  problem that is four  outputs. In fact, I need only an output
So:
The first, I want to use a multiplexer at output to have an output but I think it is diffilcult to design or look for.  I have waited for long time but nobody Answers me.
Then, I think about a switch to change instead of multilplexer.
I need to look for a switch that has four ways input and an output
Can I design it or Where I can find? Who can help me? Or Who can introduce  to me some products..
hieuphong
vietnam
Re: multiplexer
Reply #5 - Nov 11th, 2010, 7:42am
to Pancho
Maybe  you don't understand what i said and done
the first: I need to find a switch or mutiplexer at output
the second: I have to design real circuit
but, you can explaint clearly  what you want to say.
hieuphong
vietnam
Re: multiplexer
Reply #6 - Nov 11th, 2010, 8:02pm
Pancho, Can you give me some sugesters? Maybe, it is very simple with you, But, it is a big problem  with me... I want to complete  that is problem.  Can you give me some sugesters? step by step to complete...
Re: multiplexer
Reply #7 - Nov 26th, 2010, 10:48pm
I assume you use Agilent Momentum on Agilent ADS.
But you can do your task by using distributed components elements without using Momentum.
If you would like to design Hybrid alone, do 4port S-parameter analysis.
If you would like to design 1:4 power divider alone, do 5port S-parameter analysis.
If you would like to design a combination of Hybrid and 1:4 power divider, do 7port S-parameter analysis.
hieuphong wrote on Nov 11th, 2010, 7:42am:
I don't think any switch or multiplexer is required in designing.
Do you want to design actual SP4T switch ?
I think your designing targets are Hybrid and 1:4 Power Divider not SP4T switch.
However if you would like to use switch, use the following as three cascaded blocks.
http://edocs.soco.agilent.com/display/ads2009U1/SPDT+Static+%28Single+Pole+Doubl....
Or create your own switch by using Verilog-A.
Again, do you think your power dividers can work properly without termination ?
If you use "multiplexer", you have to terminate all unused outputs.
This is very true even if you implement actual switch using pin-diode.
This is very true even if you use commercial product of SP4T switch such as followings.
http://www.analog.com/static/imported-files/data_sheets/ADG904_904R.pdf
http://www.peregrine-semi.com/pdf/datasheets/pe42641ds.pdf
And this is also true for Hybrid.
Again, I don't think any switch or multiplexer is required at all in your designing tasks.
« Last Edit: Feb 5th, 2011, 10:32am by Ken Kundert »
hieuphong
vietnam
Re: multiplexer
Reply #8 - Feb 21st, 2011, 7:13pm
i don't come here for a long time. Now, i need some files or document about phase shifter. Who can help me?
i hope, everyboddy will help me because i'm a final student at university and i have to do a project to gradute.
thanks a lot!!!
hieuphong
vietnam
Re: multiplexer
Reply #9 - May 3rd, 2011, 10:40pm
Nobody want to help me. I'm desiging the hardware of project. But i have some diffilcults. it's not matching between input character and output character. I have designed about 5 verisons. Who can give me some advises, please? If i don't complete i can't graduate... Help me, please!!!!!
