Apr 27th, 2024, 3:41pm
PLL jitter and power supply bounce (Read 2482 times)
lunren
Asia
Nov 18th, 2010, 3:53pm
Hi All,
We have a signal processing chip (4 channel ADC + PLL + serializer) in 0.18um technology. The chip consumes about 170mA current. The VCO of the PLL works at 1.3GHz (differential ring oscillator, followed by duty-cycle correction circuit), the data output rate is 2.6Gbps.
The PLL and digital circuit share the same regulator and the regulator can be bypassed. During characterization, we found that the PLL have two much jitter and we have problem to send data out. We check
the power supply of the PLL, it seems that the power supply is very bad. There is a lot of bounce (300mV) in both power supply and ground. Even if we bypass the regulator, the bounce is the same as with regulator (please refer to the power supply waveform in the attachment). I am wondering why there is such big bounce? One reason I think is that it is due to the ESL of the decoupling cap connected between the power and ground because deltaV=L*dI/dt. If dI/dt is big, then very small L would create big bounce. If this is the
reason, we can maybe using small decoupling cap (means small ESL). Is there any other reason for the bounce? Any idea are welcome.
We are going to change the mask to address the jitter issue of the PLL. One way is to put deep NWELL underneath the PLL to isolate its substrate from the chip substrate. But what about the power supply and ground of the PLL? Should we put a regulator only for PLL to use? Inside the chip, the ground of the PLL is separated from other circuits, but all grounds were connected together in the PCB board. I am wondering what people usually do with the power and ground for high speed PLL? Any idea are welcome.
Lunren
Lunren
Mayank
Re: PLL jitter and power supply bounce
Reply #1 - Nov 19th, 2010, 5:20am
Bad, bad idea to use same regulator for analog vdd of the oscillator & digital soc cktry outside pll.
Watching the supply profile, & assuming digital cktry is not working exactly at 1.3 GHz, the supply profile seems to be dominated by VCO current itself.
Is the regulator working properly ?
Is the chosen o/p bypass cap value enough to tolerate vco supply current profile ?
Has the VCO supply current profile changed from wot the ldo was designed for ?
Localize the jitter source -- if it's from power suplpy ripples due to digital cktry operation, then try n manage with the bypass cap.
If not possible, then go for a separate ldo for pll.
Havent seen ESL playin such a big role so as to be noticeably this large in on-chip caps. If it's off-chip, definitely check ESL, & try n fit these ripple magnitudes with ESL value obtained. if it fits, could explain these inductive voltage peaks.
--Mayank.
raja.cedt
Reply #2 - Nov 19th, 2010, 6:34am
hi,
as maynak said hanging both digital and analog to an regulator is not good idea,
1.whats your regulator psrr and whats the ripple on the regulator. BY finding the ripple and vco frequency senesetivity you estimate whats the impact of the vco on jitter
2.Try to increase the decap at the regulator O/P.
3.Do you have any probing points for pll critical nodes like vcontrol, if so check the ripple and through Kvco also you can estimate impact.
4.Whats the Kvco?
5. Is there any correlation for supply noise frequency and digital stuff frequency, if so you can suspect ESl I guess ESL.
Thanks.
lunren
Asia
Reply #3 - Nov 19th, 2010, 12:34pm
Yes, the regulator works properly.
Yes, the o/p bypass cap is big enough to tolerate supply current profile.
No way to measure the VCO supply current profile. But the chip current consumption doesn't change from what we designed for.
Yes, one of our plan is to separate the power supply of PLL and digital circuit and only the PLL use that regulator.
The caps are off-chip.
--Mayank.
Lunren
lunren
Asia
Reply #4 - Nov 19th, 2010, 12:50pm
hi,
The PSR of the regulator is only -5dB at the frequency that VCO works (1.3GHz). Maybe we need change the regulator structure so that we can have very good PSR at very high frequency?
Because the dropout is only 200mV, so the size of the PMOS is big which make the dominant pole locates at the gate of the PMOS. So if we increase the decap too much, it would be unstable.
Yes, we use off-chip loop filter. We can probe vctrl.
Quote:
4.Whats the Kvco?
3GHz/V
From the attachment, we can see that there are two frequency on the power profile, 12MHz and 100MHz. But in the digital circuit, we don't have such a working frequency.
raja.cedt & Mayank,
Do you usually power the PLL (especially high speed PLL) with a separate regulator?
Thanks.
Lunren
raja.cedt
Reply #5 - Nov 19th, 2010, 7:24pm
hi,
Using isolated regulator for pll is very good idea but often most designers use separate regulator for vco and if possible another for all or may be only for charge pump. By the whats the ripple on the control voltage and whats the ripple at the regulator output (i guess this should be around 70mv because regulator psrr is -5db and 130mv is the supply noise)
Thanks.
Mayank
Reply #6 - Nov 22nd, 2010, 4:18am
Yes we do.
Separate LDOs for CPUMP & VCO & other internal blocks of pll are required in only v tight jitter spec plls.
Usually a single separate ldo for pll's analog supply is enough.
--M
lunren
Asia
Reply #7 - Nov 22nd, 2010, 4:37pm
The voltage profile at the output of the regulator is the one shown in the first post.
In this attachment of this post, the ripple profile on the control voltage will be shown. The reference frequency is 26MHz (period is 38.46ns). It seems that the control voltage has two much ripples. I don't know why there is too much rings at interval of the 38.46ns, maybe the PFD+charge_pump has dead zone?
Lunren
lunren
Asia
Reply #8 - Nov 22nd, 2010, 4:47pm
Hi Mayank, should the separate LDOs for CPUMP & VCO have very good power supply rejection at ALL frequency? How do you define the PSR spec for PLL? Any comments on the PSR profile (pink on in the attached file) of the regulator we will be using for the PLL are welcome.
Lunren
Lunren
raja.cedt
Reply #9 - Nov 22nd, 2010, 11:31pm
hi,
regulator has very poor psrr  man, the main reason i could see is you have 80 phase margin better don't go for that large value because psrr will improve if  2nd pole of the regulator is near to BW, hence  better psrr and less pm. So just drag the 2nd pole near to BW and check the psrr. Try to maintain at least 20db (its a general rule of thumb) across frequency BW. Regarding control node voltage variation i didn't see such type of variation i guessing that your filtering cap is very less.
Thanks.
Mayank
Reply #10 - Nov 23rd, 2010, 7:55pm
Chielfy by vco supply current profile, & reference spur suppression.
Average. Could be improved if needed.
