Apr 26th, 2024, 11:53am
Help: how to recover files deleted from the library manager in cadence? (Read 8817 times)
x1346
CHINA
Dec 07th, 2010, 4:17am
I deleted some design files in the library manager by mistake. (My designs are on a server and I log in using a shell. And there is no other people using that server.) Who knows how to recover the lost files?
Thanks in advance.
sandy
AnalogDE
Re: Help: how to recover files deleted from the library manager in cadence?
Reply #1 - Dec 7th, 2010, 2:50pm
Contact your design automation people -- they may be able to retrieve a backup...
carlgrace
Berkeley, CA
Reply #2 - Dec 7th, 2010, 4:09pm
Are you using a version control system such as SOS?  It creates automatic backups when you check in new versions of cells.
x1346
CHINA
Reply #3 - Dec 9th, 2010, 7:22am
Till now I haven't found it has that function. Some one has tried in the ext2 file system, while the file system of the server I'm using is ext3. So I don't know whether there is a way to retrieve the deleted files.
sweetemo22jd
Reply #4 - Feb 15th, 2011, 5:09pm
Once you delete a library from a library manager, that file becomes deleted from your disk. Well, you may try to include the library and path in your cds.lib. If all else fails, try downloading a data recovery pro software. It might help you retrieve a backup.
weber8722
Reply #5 - Nov 18th, 2011, 1:19am
Out IT makes hourly snapshots of all project data. That helped us many times  :) Smiley. Using a version sync software is also a good idea - but many analog designers hate it (at least for 99% of the time).
Bye Stephan
