Aug 16th, 2024, 8:02pm
Cadence Virtuoso and ADS momentum (Read 4715 times)
abhishek
Minneapolis
Dec 08th, 2010, 8:34am
I have to make a simple inductive filter circuit in Cadence Virtuoso. The schematic part is OK but I do not see any standard cell layout for inductor in the kit. I am new to analog/RF design and unsure how to go about it.
I understand ADS momentum can do layout for inductors. Can I use Cadence Virtuoso and ADS momentum together? How do I import the layout made in momentum to Cadence.
Please guide.
Abhi
Abhishek Arun
Department of Electrical & Computer Engineering
University of Minnesota
Minneapolis, MN, 55455
Cell: 612-670-3107
abhishek
Minneapolis
Re: Cadence Virtuoso and ADS momentum
Reply #1 - Dec 8th, 2010, 8:56am
Thanks for your reply.
Then what is the method to layout an inductor if it is not given in the standard cell?
I can draw a metal ring, but how would I define the number of rings and other parameters for an inductor. LVS error will also come up as it would treat it as a wire.
Any suggestions?
Abhishek Arun
Cell: 612-670-3107
