Aug 14th, 2024, 11:43am
Generating liberty (.lib) files for analog blocks. (Read 200 times)
BillH
San Diego
Dec 21st, 2010, 11:04am
What is the best way to generate liberty (.lib) format timing files for an analog block (e.g. PLL) to be used in a digital top level integration flow?
So far, we have basically used a combination of legacy liberty files and hand-editting new information.
But I was wondering if there are standard tools or flows used for this step?
Thanks.
haykp
Re: Generating liberty (.lib) files for analog blocks.
Reply #1 - Dec 23rd, 2010, 12:12am
You can use synopsys libertyNCX tool to generate the lib file.
The tool mainly needs extracted input, model files and hspice simulator access.
Reply #2 - Jan 2nd, 2011, 12:38pm
There is also a capability in DCM (part of ADE GXL) in Cadence's IC61 release which can help with generation of .lib for mixed signal blocks.
