sheldon wrote on Mar 22nd, 2011, 5:19am:Rob,
The ability to change the X-axis has been in Virtuoso for a long time,
look at the x-axis properties and change the variables.
Thanks, but did you have to point out that "long time" part ;D I actually think I figured it out and then forgot it now that you mention it.
Quote:As for sending
data to the calculator in IC61, hover the mouse over the data you
want to plot and click the right mouse button [RMB]. While holding the
RMB down select calculator from the menu.
Not sure what you are describing, but I want to send the data to an external file and process it with Matlab. I think it was the "printvs" command that used to do it. I'm sure it is something simple... I just haven't had enough time to search it out. Maybe the OP needs to know too.
Wanna give a quick primer on what the dnl function does?
Rob
