Verilog-AMS
Analysis
Modeling
Design
Theory
Welcome, Guest. Please
Login
or
Register.
Please follow the Forum
guidelines
May 23
rd
, 2024, 4:03pm
Home
Help
Search
Login
Register
PM to admin
Other CAD Tools
Physical Verification, Extraction and Analysis
› Extract a non-regular resistor with Assura
Previous topic
Next topic
Extract a non-regular resistor with Assura (Read 5968 times)
May 18
th
, 2011, 8:58am
Hi Guys,
I am trying to extract a non-regulat resistor with Assura. It reports "Mal-formed Device" and stops. I will attach the schematic and layout in the following. Any comments are appreciated.
Yawei
IP Logged
Re: Extract a non-regular resistor with Assura
Reply #1 -
May 18
th
, 2011, 9:00am
The layout of the 4 resistors is a continuous poly silicon strip, instead of 4 poly strips connected by metal path and contacts.
IP Logged
Reply #2 -
May 18
th
, 2011, 9:01am
It is zoomed in to show the detail of the tap.
IP Logged
boe
Reply #3 -
May 19
th
, 2011, 7:46am
Ywguo,
it seems your PDK does not support this.
B O E
IP Logged
Reply #4 -
May 19
th
, 2011, 7:31pm
B O E,
You are right. I don't think that PDK has a non-rectangular shaped resistor pcell. But is it possible to modify Assura/Calibre runset so that this is recognized?
Yawei
IP Logged
boe
Reply #5 -
May 20
th
, 2011, 1:08pm
Ywguo,
It is not only a question of the pcell.
You should decide how to handle the following problems:
How do you want your non-rectangular resistor to be extracted? What is its value(s)?
With answers to that you can try to write rules for Assura or Calibre implementing that.
B O E
IP Logged
rfidea
Europe
Reply #6 -
May 21
st
, 2011, 12:37am
Why just not put four real resistors in the layout and connect them by metal1? Probably you can put the contact areas on top of eachother to save some length if that is your problem.
IP Logged
rf-design
Reiner Franke
Reply #7 -
Jun 6
th
, 2011, 5:46am
Multitap resistors is a typical examples where standard analog techniques and minimum designkits are conflicting. Typical designkits serve the bare minimum analog design. They exclude many good analog methods and there modelling hide often important technology effects worth knowing because of liability reasons.
The multitap poly resistor requires a complete separation of the pure poly resistor rectangle and a second poly resistor tap rectangle. The extracted net where the tap contact the poly bar must be created by separating the poly bar into multiple resistor recognition rectangles touching each other. The touching line with the poly tap rectangle produce a T-form. For precision application there is a nonlinear correction function with change the pure rectangle extraction values of the three resistors depending on the width ratio of the tap to the bar.
IP Logged
Previous topic
Next topic
Forum Jump »
» 10 most recent Posts
» 10 most recent Topics
Design
- RF Design
- Analog Design
- Mixed-Signal Design
- High-Speed I/O Design
- High-Power Design
- Mixed-Technology Design
Analog Verification
Measurements
- RF Measurements
- Other Measurements
Modeling
- Semiconductor Devices
- Passive Devices
- Behavioral Models
Design Languages
- Verilog-AMS
- VHDL-AMS
Simulators
- Circuit Simulators
- RF Simulators
- AMS Simulators
- Timing Simulators
- System Simulators
- Logic Simulators
Other CAD Tools
- Entry Tools
»» Physical Verification, Extraction and Analysis
- Unmet Needs in Analog CAD
General
- Tech Talk
- News
- Comments and Suggestions
- Opportunities
« Home
‹ Board
» Powered by
YaBB 2.2.2
YaBB
Copyright 2002-2024
Designer’s Guide
All rights reserved.
Send comments or questions to
editor@designers-guide.org
. Consider
submitting
a paper or model.
