Jul 16th, 2024, 4:37am
Trouble writing VerilogA model for a circuit block with vdd! input pin (Read 2956 times)
SJ
May 24th, 2011, 7:00pm
 I am trying to write VerilogA behavioral models for some sub-blocks/sub circuits in our existing IC designs. One of the sub blocks has a pin vdd!. When I generate a veriloga module template using the VerilogA editor, the port appears in the port declarations and pin names as \vdd!. On my top level test schematic, I have a 3.3V supply connected that acts as vdd!. In the config view, when I set up the view to use as schematic, there is no problem and the circuit simulates fine. However when I change the view to VerilogA there is a netlister error.
ERROR: Netlister : terminal 'vdd!' of instance 'I4', in cell 'ClkGenerator', view 'schematic' : cannot be found in the switched master of the instance.
Anyone have any ideas on how to make this work?
boe
Re: Trouble writing VerilogA model for a circuit block with vdd! input pin
Reply #1 - May 27th, 2011, 10:10am
SJ,
rename the pin in the schematic.
B O E
PS: Do you know where this name comes from? And which tools do you use?
