May 18th, 2024, 8:17am
Extraction Problem in Cadence Assura (Read 2999 times)
analog_design
INDIA
Jun 22nd, 2011, 5:44am
When I do netlisting of av_extracted view of RC extracted layout. Aspect ratio of transistor is matching with schematic design. I mean, sizing of circuit (schematic) in netlist is not reflecting in extracted netlist. some time, if two device are in cascode position then, upper one's aspect ratio is reflected in lower one's size.
I do not where exactly going wrong? I believe it must be with model files. I am not sure about it.
Please, let me know your opinion and solution.
I would appreciate it.
Thank You,
Warm Regards
View Profile analog_design   IP Logged
analog_design
INDIA
Re: Extraction Problem in Cadence Assura
Reply #1 - Jun 22nd, 2011, 5:45am
I am sorry (not matching with)
Warm Regards
