Sep 22nd, 2026, 6:15am
Pages: 1 2 3
Question about phase noise simulation result (Read 20077 times)
Frank Wiedmann
Munich, Germany
Re: Question about phase noise simulation result
Reply #30 - Nov 25th, 2015, 12:53am
In general, there is no direct correlation between time domain (strobed, jitter) and averaged ("sources") pnoise results (see http://support.cadence.com/wps/mypoc/cos?uri=deeplinkmin:ViewSolution;DocumentTy...).
deba
Reply #31 - Feb 21st, 2018, 3:54am
It is a very useful thread.
I have few questions, I hope someone can answer.
If someone is designing a clock buffer circuit. The AM noise can be removed by passing the clock output through an ideal VCVS with gain of 1, centred around Vdd/2. Thus, there is only PM noise present in the circuit. Here the sources (time average) method can be used to calculate the phase noise.
But when I use PM-jitter for this circuit, the results are almost 2x compared to sources. Can some one please help in this? Is the method of using VCVS with voltage limit correct?
deba
Reply #32 - Feb 21st, 2018, 10:54pm
A follow up question.
Passing the clock output through an ideal VCVS of gain=1 and voltage limits of +/-100 mV around the threshold(mid-value) suppresses the AM noise? Is the above statement correct?
Pages: 1 2 3
