Aug 3rd, 2024, 1:17am
large signal bandwidth of amp (Read 803 times)
chaojixin
Shanghai
Jul 25th, 2011, 5:52pm
i read the datasheet of TI's 'ths3121' and find this term which is somewhat smaller than the small signal bandwidth. what's the large signal bandwidth and what's the relationship between large signal bandwidth, small signal bandwidth and slew rate?
any reference about the analysis of 'large signal bandwidth'?
thanks!
View Profile chaojixin chaojixin 278916917   IP Logged
buddypoor
Bremen, Germany
Re: large signal bandwidth of amp
Reply #1 - Jul 25th, 2011, 11:49pm
The large signal bandwidth (caused by the slew rate) is:
BW=SR/(2*Pi*umax)   with SR=slew rate and umax=amplitude of the maximum possible sinusoidal output voltage.
Note that BW as well as SR are defined for an opamp with large negative feedback (some times 100% if stability allows).
There is no direct relation to the small signal bandwidth.
Jewel Jubic
Reply #2 - Aug 8th, 2011, 4:54am
It can be described on the basis of front end's ability to get a signal from because the distortion performance of an amplifier does not remain constant..
buddypoor
Bremen, Germany
Reply #3 - Aug 8th, 2011, 5:21am
Jewel Jubic wrote on Aug 8th, 2011, 4:54am:
Does anybody understand? I am always willing to learn but....
