Sep 2nd, 2024, 1:15pm
Pages: 1 2 3
uncompensated opamp - frequency of oscillation (Read 20548 times)
raja.cedt
Re: uncompensated opamp - frequency of oscillation
Reply #30 - Oct 01st, 2011, 2:12am
hello buddypoor,
yes you are correct, but here PM and gain margin doesn't look good, infact stability margin (means how close your nyquist plot to (-1,0) point) would give better result.
Thanks.
Raj.
buddypoor
Bremen, Germany
Reply #31 - Oct 1st, 2011, 2:27am
Yes, I agree. I think, you are referring to the so called "vector margin" or "stability radius".
buddypoor
Bremen, Germany
Reply #32 - Oct 1st, 2011, 5:32am
Hi RAJ,
here is an additional information - perhaps it is new for you:
The mentioned vector margin (min. distance between T(s) and "1" in the Nyquist plane) can be easily found:
Display 1/abs(1-T(s)) and find the maximum of this curve.
The inverese of this maximum gives this stability measure.
In your example: margin app 1/3.85 which is rather poor.
(T(s) is the real loop gain - including sign inversion at the summing node).
rajkumar palwai
Sunnyvale, California
Reply #33 - Oct 1st, 2011, 5:54am
Hi Raja, buddypoor
Thanks for the information. So i should use the bode only for all pole system and nyquist for systems with zero's.
i guess i need to study more about nyquist plots as I am not very comfortable with them.
-Rajkumar
raja.cedt
Reply #34 - Oct 1st, 2011, 7:07am
hello rajkumar,
yes, for all pole systems (or monotonic mag and phase responce) you can apply bode with out any issue. You can refer this book for all the details "Feedback Systems: An Introduction for Scientists and Engineers ".
@buddypoor: do you know any simulator which can plot Nyquist plot, i know LTspice can.
Raj.
buddypoor
Bremen, Germany
Reply #35 - Oct 1st, 2011, 8:25am
In most cases I work with PSPice - and, of course, it can display the Nyquist curve. Microcap and Simetrix as well.
I don`t like LTSpice to much because - for my opinion - it is not very convenient. I cannot play with parts and expressions and displays like PSPice allows.
Pages: 1 2 3
