Apr 27th, 2024, 10:51pm
Analog  Verification (Read 9651 times)
neetirajgor
India
Analog  Verification
Sep 26th, 2011, 10:18pm
HI
I am M.tech student.
My dissertation topic is "analog verification".
I would like know about which are the Cadence tool available for analog verification because I m right now going through feasibility phase.
« Last Edit: Sep 27th, 2011, 7:46am by neetirajgor »
Re: Analog  Verification
Reply #1 - Oct 6th, 2011, 6:56pm
I assume you do analog function verification with verilog-AMS. If you choose cadence tool, you need ncvlog/ncelab/ncsim and spectre simulator. ncvlog/ncelab/ncsim are integrated in IUS stream, which is combined in INCISIVE stream since INCISIVE 9.x. You need IC stream (ic 5.x or ic 6.x) or MMSIM for spectre simulator.
boe
Reply #2 - Oct 7th, 2011, 1:42am
Neetirajgor,
Simulators are Spectre or - for large designs - APS and UltraSim Fast SPICE. They all support analog modeling using Verilog-A. If you need digital as well, you should go for Verilog-AMS (or perhaps VHDL-AMS) using the simulators ywguo mentioned.
If you are interested in Methodology/Design Flow, e.g. use of digital design methodology for analog blocks, you should check the digital tools. There used to be attempts to extend them to mixed-signal designs - don't know about their status though.
- B O E
Reply #3 - Oct 27th, 2011, 4:58pm
MehaboobAli
BANGALORE
Reply #4 - Aug 9th, 2012, 12:28am
Hi
Can I get any reference to NCSim.
Is NClaunch and NCSim same.
Ali
