May 17th, 2024, 12:53am
VERILOG-A and imaginary numbers and functions (Read 5717 times)
T-4444
Oct 12th, 2011, 5:32am
Hi there,
I am working on a compact model for a FinFET transistor in verilog-a, and I have a problem.
I have some equations and functions which deal with imaginary numbers. For instance:
u1v1 = cosh(`M_PI * (xm + i*(toxs_t + Tch/2)) / (2 * toxs_t + Tch));
Now I have to store the real and imaginary part into seperate variables, so I can use them later on. How does this work? In Matlab, for example, you can easily say: a=real(u1v1), and b=imag(u1v1).
Do you have an idea?
Thanks in advance
Re: VERILOG-A and imaginary numbers and functions
Reply #1 - Oct 12th, 2011, 10:03am
What do you need complex numbers for?  (Verilog-A doesn't provide support for them.)
In one case, people wanted complex numbers to do correlated noise, and the solution was to use a ddt() formulation that gave rise to a 1/jω dependence (which was what was wanted -- not just the "j").
T-4444
Reply #2 - Oct 18th, 2011, 11:04pm
I need complex numbers because I am using the conformal mapping technique (which is based on complex functions) in order to calculate the electrostatics of my device, and finally the output current.
Anyway, I will try to do a workaround. When its done, I will post the result.
Thanks for replying.
