NTR
Hi BOE, Thank you for your answer and your valuable time . You are correct. But for time being I have used "lsim(tf, input,time)" to get tf response to arbitrary input. It seems working fine. May I ask you one more question? What are the key aspects system designer must look at for behavioral modeling first order integrator with (unity gain bandwidth)UGBW 2GHz, DC gain should as high as possible and cutoff frequency must be very low. I am solving this by using tf=G_dc*Wp/s+Wp where Wp is cutoff freq and G_dc --dc gain. Here How can i specify UGBW in the transfer function. thank you once again.
