May 19th, 2024, 2:11am
First order GmC integrator (Read 5259 times)
NTR
Oct 23rd, 2011, 2:02am
I am implementing integrator with tf for ex "tf=1/s+10".I know that in simulink it is easy to implement but I want to do it matlab code. So I am applying this tf to input signal with the help of filter function available in matlab like this "out=filter(tf,input_signal)"; my output should be integrated signal. But its behaving like low pass filter. Please correct me if I am doing wrong in applying integrator transfer function to input.
Thanks for help.
boe
Re: First order GmC integrator
Reply #1 - Oct 24th, 2011, 1:08am
NTR,
the MATLAB function filter expects a z-domain transfer function, not an s-domain TF. You can use the MATLAB function bilinear to convert from s-domain to z-domain.
Does this help?
- B O E
NTR
Reply #2 - Oct 24th, 2011, 2:08am
Hi BOE,
Thank you for your answer and your valuable time . You are correct. But for time being I have used "lsim(tf, input,time)" to get tf response to arbitrary input. It seems working fine.
May I ask you one more question?
What are the key aspects system designer must look at for behavioral modeling first order integrator with (unity gain bandwidth)UGBW 2GHz, DC gain should as high as possible and cutoff frequency must be very low.
I am solving this by using tf=G_dc*Wp/s+Wp     where Wp is cutoff freq and G_dc --dc gain.
Here How can i specify UGBW in the transfer function.
thank you once again.
boe
Reply #3 - Oct 24th, 2011, 2:34am
NTR,
UGBW, cut-off frequency and gain are not independent. You have only two degrees of freedom in a first-order system (without zeros, of course).
- B O E
NTR
Reply #4 - Oct 25th, 2011, 3:00pm
HI BOE,
Yes. I think I have to read more about integrator to understand better its design issues at system level.
How to decide saturation limits of integrator based on its transfer function?
/NTR
boe
Reply #5 - Oct 27th, 2011, 3:46am
Hi NTR,
NTR wrote on Oct 25th, 2011, 3:00pm:
The transfer function describes the integrator in the linear region, while saturation occurs when you leave the linear region.
Thus, the saturation limits depend on you integrator implementation and your accuracy requirements.
- B O E
