Aug 14th, 2024, 9:16pm
Jitter estimation on synchronous counter (Read 4112 times)
HdrChopper
Nov 09th, 2011, 4:54pm
Dear  colleagues,
Assuming I know how much jitter my reference clock has, I need to estimate de jitter of synchronous counter of N stages.
If the reference clock jitter is jck my gut feeling is that the total jitter should be jck*√N (assuming uncorrelated jitter between stages).
Is this correct? Any other considerations (or references)?
Tosei
Keep it simple
rajkumar palwai
Sunnyvale, California
Re: Jitter estimation on synchronous counter
Reply #1 - Nov 9th, 2011, 8:28pm
Tosei,
For any flip-flop, the inherent noise in the devices also add jitter at the o/p. So, if the ref clk has jitter of 'jck' and the device noise add a jitter of 'jdn', then the total jitter at the o/p would be rms average of jck & jdn.
For synchronous dividers, jitter doesn' accumulate between stages. Because the jitter at the o/p of the final flop just depends on the jck and its own noise at that time.
rajkumar palwai
Reply #2 - Nov 9th, 2011, 8:29pm
Jitter accumulation happens in ripple counters where, each stage jitter affects the next stage transition.
