carlgrace wrote on Nov 11th, 2011, 10:16am:So I got a little more information. It seems I need a scope with at least 1.5X the bandwidth of the bitrate (based on third harmonic of 1010101 pattern). So a storage scope with 15 GHz input bandwidth would work. Can I do the BERT with an FPGA based solution?
At those data rates you are going to have to set up a parallel data path in something at a lower frequency, and then recombine the signals to make the higher data rate in a specialized device.
Why don't you look around at whats out there already for SerDes xmitters or optical drivers?
At these data rates there is going to need to be pre-emphasis in the Xmit however.
I presume this is research at Cal?
