analog_power
I designed a model for hall element and everything works fine. Now, I am on that state, where I want to put statistical parameters in it. I want that the parameters change with every simulation according to normal distribution. I want to use Monte Carlo simulation.
If I add "$rdist_normal($random,0,1)" to a resistor value, the value changes several times in a DC-sweep analysis, because the variable change at every look at this line.
When add this line in the initial block, then the simulator gets stacked.
How can I do that right?
