Jul 1st, 2025, 11:05pm
Verilog-A Statistical Variations (Read 16424 times)
analog_power
Dec 12th, 2011, 1:22am
I designed a model for hall element and everything works fine.
Now, I am on that state, where I want to put statistical parameters in it. I want that the parameters change with every simulation according to normal distribution. I want to use Monte Carlo simulation.
If I add "$rdist_normal($random,0,1)" to a resistor value, the value changes several times in a DC-sweep analysis, because the variable change at every look at this line.
When add this line in the initial block, then the simulator gets stacked.
How can I do that right?
boe
Re: Verilog-A Statistical Variations
Reply #1 - Dec 12th, 2011, 5:55am
Hi analog_power,
are you sure that your simulator allows $rdist_normal in a digital context (initial block)?
- B O E
PS: Which simulator do you use? What does "gets stacked" mean exactly?
analog_power
Reply #2 - Dec 12th, 2011, 6:42am
I am not sure about that. Obviously it isn't allowed.
I am using spectre.
I am sorry, I tried to say that the simulation got stucked. I mean that there is no change in the progress bar.
Frank Wiedmann
Munich, Germany
Reply #3 - Dec 12th, 2011, 6:54am
Are you talking about the digital initial block or the analog @(initial_step)? I don't see a reason why the latter shouldn't work and would consider it a bug if it doesn't.
Forum Administrator
YaBB Administrator
Reply #4 - Dec 12th, 2011, 10:20am
Try changing the transient method option to gear2only.
analog_power
Reply #5 - Dec 13th, 2011, 12:46am
I am talking about the @(initial_step block).
But is that the right way for making the model work with Monte-Carlo?
Ken,
what do you mean with gear2only ?
analog_power
Reply #6 - Dec 14th, 2011, 5:44am
Now I know, what you mean with gear2only and it didn't change anything.
analog_power
Reply #7 - Dec 14th, 2011, 7:30am
I still couldn't solve my problem.
Just an update:
I want to implement statistical Variations in my model. Independent of simulation mode. There should be different results even when I run manually simulations, without Monte Carlo or similar.
Has anybody an idea?
Forum Administrator
YaBB Administrator
Reply #8 - Dec 14th, 2011, 12:10pm
Saying the simulator is stuck does not really provide enough information. And given that the simple things did not work, it is time to try a little harder to figure out what is happening. The first question is: is the simulator really stuck, or is it just running very slowly. You might be able to figure this out by looking at the waveforms over time and see if they continue to grow. You might also have the waveform tool show you the time points and then explore what changed when the time steps dramatically shrunk. That might lead you to the cause of the problem. Alternatively, you can put the following line in a Verilog-A model:
    $strobe("%0.15e", $abstime);
That will print the time to 15 digits, which should allow you to see whether time is progressing.
Marq Kole
Hmmm. That's
weird...
Eindhoven, The Netherlands
Reply #9 - Jan 18th, 2012, 12:49am
Just some musings, but if you use $rdist_normal($random,0,1) it appears to be a bit overly random. Especially the DC might have an issue. Wouldn't it be better to use
parameter integer seed = 123456;
integer iseed;
analog initial iseed = seed;
analog begin
  value = $rdist_normal(iseed, 0, 1);
boe
Reply #10 - Feb 14th, 2012, 1:07am
Marq Kole wrote on Jan 18th, 2012, 12:49am:
integer iseed;
analog begin
Marq,
unfortunately, the simulator performs the analog initial block for every MC run (at least mine does), so you get identical results for all runs.
- B O E
jerome_ams
Reply #11 - Jul 12th, 2012, 2:23am
would VHDL be an option in your case? Some activities have been driven in Europe to develop an open source Statisitcal Package for both VHDL(AMS) and SystemC(AMS)
Cheers
J
Reply #12 - Jul 18th, 2012, 9:59am
I think Jerome_ams's post here:
http://www.designers-guide.org/Forum/YaBB.pl?num=1341703776
may be more appropriate to what analog_power wants to do.
Let the simulator set the random parameter values by using statistics blocks, and assign those values on the instance line of the Verilog-A model -- just like you would do for MC of a Spice built-in primitive.
Hadi
Reply #13 - Aug 7th, 2012, 4:07pm
Hi everyone,
I simulated Hall element in COMSOL, but now, i want to design Hall element in Verilog-A.
I would appreciate if you could help me to design Hall element in Verilog-A...
Best,
Hadi
