Aug 14th, 2024, 2:21pm
UltrasimVerilog error: failed to parse the netlist (Read 182 times)
ahhfyz
Jan 12th, 2012, 11:00pm
Hi, everyone!
I have a system including verilog (modules and sub-modules) and schematic. It can be simulated in SpectreVerilog, but failed in UltrasimVerilog:
"Error found by UltraSim.
ERROR (USIM-18610): The UltraSim simulator failed to parse the netlist.
Correct the above errors and run the simulation again."
What should I do next? Thank you!
AMS_ei
Re: UltrasimVerilog error: failed to parse the netlist
Reply #1 - Aug 2nd, 2016, 4:49am
Please use the following two lines and check if it works.
-sysv_ext +.v
-simcompatible_ams spectre
Thank you.
