singh
hello,
i was going through a paper for noise calculation the circuit. I have atached the expression below.
I am just little bit confusing with the units of PSD in terms of Amp^2/Hz
the expression has KF which is unitless Cox is Farad/length^2 Wl gives unit of length^2 and freqency is Hz gm2 is siemesn2
if i do calculation, i am left with unints siemen^2/ (Farad* Hz)
first combination of units of gm/C gives current hence Ampere..but now thr is only gm left in expression.
so how it is ampere^2 /Hz in formula for PSD?
