Aug 15th, 2024, 5:29am
asking about the implicit equation when using verilog-A (Read 182 times)
dabier
Feb 20th, 2012, 3:40pm
I was doing a behavior modeling of electronics devices. and in the model i need to declare a real type variable. and this variable is a function of time and can be defined from a differential equation implicitly, so can i just put the equation in the model and will the simulator automatically handle this? i just know that only a contribution can handle this implicit equation, how about a variable?   thanks!!
View Profile dabier   IP Logged
Re: asking about the implicit equation when using verilog-A
Reply #1 - Feb 21st, 2012, 6:13am
I'm pretty sure you'll need to set up a contribution to handle this; this will force you to select a discipline for the variable, which then sets the tolerances (absolute and relative) so that the solver knows how accurately it needs to resolve the value.
dabier
Reply #2 - Feb 21st, 2012, 9:04am
Thank you very much. i know what to do now!!
boe
Reply #3 - Feb 23rd, 2012, 3:36am
dabier,
you might want to try an indirect branch assignment:
V(out) : V(in) == 0 ; //find V(out) such that V(in) is zero
- B O E
