Aug 31st, 2024, 7:06pm
Die per Wafer ! (Read 1533 times)
modu
Die per Wafer !
Feb 24th, 2012, 3:29am
Hello Everyone ! I'm currently reading a book about computer Architecture and i know that the number of die per wafer can be calculated as : dies per wafer = [PI*(waferdiameter/2)^2]/die area – (PI*waferdiameter)/sqrt(2*die area) .
I was reading this example : Find the number of dies per 300mm (30 cm) wafer for a die that is 1.5 cm on a side .
The answer say : The die is 2.25 cm^2 .Thus
Die per wafer = PI * (30/2)2 / 2.25   - (PI * 30) / Sqrt( 2* 2.25) = 270.
my problem is where did the 2.25 come from ? Please help ?
boe
Re: Die per Wafer !
Reply #1 - Feb 24th, 2012, 5:46am
Modu,
A hint: How do you calculate the area of a rectangle?
- B O E
modu
Re: Die per Wafer !
Reply #2 - Feb 24th, 2012, 9:11am
Area of rectangle is : Width x Height .
so, which means the 1.5 cm is only one side/ half  of the area ?
Re: Die per Wafer !
Reply #3 - Feb 24th, 2012, 2:17pm
please, is this a joke?
1.5cm is the length of one side
the die is square
1.5 X 1.5 = 2.25cm^2 which is the area.
