Jul 16th, 2024, 2:57pm
Plotting Ft vs Id (Read 5924 times)
vaidy.ts
Plotting Ft vs Id
Apr 10th, 2012, 3:53am
I have a Cadence ADE schematic with voltage sources vg and vd (I am simulating a MOSFET). Vg is varied and at each Vg, frequency is swept and Ft is calculated. In the calculator, I am able to specify and plot Ft vs Vg and Id vs Vg, but not Ft vs Id. Can anyone help me with this?
Vaid
boe
Re: Plotting Ft vs Id
Reply #1 - Apr 16th, 2012, 8:58am
Hi vaidy.ts,
Plot both and use Id as x-axis.
Does this help?
- B O E
vaidy.ts
Reply #2 - Apr 16th, 2012, 11:13pm
Hi BOE,
I tried, but I couldn't figure out how to plot versus the dependent variable Id. The calculator seems to implicitly use the sweep variable Vg as the x-axis. Lets say I have two sub-plots Id-Vg and Ft-Vg. If it is not too much of a trouble could you explain in words how to do it.
VTS
boe
Reply #3 - Apr 17th, 2012, 10:41am
Hi vaidy.ts,
The calculator always plots versus the independent variable (in your case Vg).
You should plot both curves in one sub-window; then you should look for parameters/attributes of the x-axis. There, you should be able to select vs. which waveform you want to plot.
Does this help?
- B O E
Reply #4 - Apr 24th, 2012, 5:52am
Vaid,
  Here is a link to a detailed discussion of how to perform the
measurement. In addition, there are other appends that cover
the details of how setup the simulation properly and how to
measure fmax.
  http://www.cadence.com/Community/blogs/rf/archive/2008/08/09/simulating-mos-tran...
