ic_engr
Hello Everyone,
I have a fundamental question regards to using the Phase Noise to estimate jitter for Sigma Delta. I can estimate the maximum sampling jitter for ADC as below:
For a Discrete Oversampling ADC, the maximum jitter can be computed as follows by the known expression:
J=(10-SNR/20)÷(2πfB).(√2.M),
where M=OSR, fB=Bandwidth of the ADC.
Usign the above expression for an OSR-133, BW=16kHz SNR=96dB
The maximum jitter allowed in sampling is: 2.56nSec (RMS)
For sampling the ADC, I am designing a ring oscillator generating 4.0MHz used as a sampling clock. I plotted the phase noise of the oscillator. My challenge now is for intgeration of phase noise what offset frequency lower limit should I use to compute jitter for my ring oscillator. Since I cannot violate the 2.56nsec.
The phase noise of my ring oscillator is as below
offset freq L(f) 1. 100Hz -29.85dBc 2. 1kHz -59.87dBc 3. 100kHz -118.3kHz 4. 2.0MHz -148.9MHz
so when integrating the above phase noise should I integrate from 100Hz to 8.0MHz or from 1kHz to 8.0MHz ?
Depending what BW I use for integration I get different jitter number. But I need to make sure I am not violating my 2.56nsec.
Todate, I have not found any literature that explains what lower integration limit for offset freqquency be used for oscillator based on ADC requirement.
ic_engr.
