Jul 31st, 2024, 3:23pm
Pages: 1 2
DC offset cancellation (Read 3348 times)
RobG
Bozeman, MT
Re: DC offset cancellation
Reply #15 - Apr 24th, 2012, 6:21am
loose-electron wrote on Apr 23rd, 2012, 8:14pm:
This method gets used in GSM receivers for many years with the offset setting frozen for the TDMX cycle. (Adjust while transmitting, freeze setting while receiving.)
OK, I understand what you are doing now. I didn't realize you were holding the correction value since that hasn't been an option for me (excepting when you ping-pong between two zeroed amps). Yes, that would be probably be better if you have two different modes.
Reply #16 - Apr 24th, 2012, 2:29pm
RobG wrote on Apr 24th, 2012, 6:21am:
Like I said - you can also do it in a continuous mode ,
as long as the feedback offset steps are a small amount of the received signal.
I don't see what the problem is visualizing this.
This stuff is old news you don't see it in IEEE JSSC
publications, because its been around so long.
RobG
Bozeman, MT
Reply #17 - Apr 24th, 2012, 2:48pm
loose-electron wrote on Apr 24th, 2012, 2:29pm:
Well duh, even I can see that  ;) But won't that put a 1 lsb tone at the update frequency?
Reply #18 - May 5th, 2012, 10:46am
sure will, but that can be dealt with, and you have a lot of freedom in how you control your feedback updates.
Pages: 1 2
