RobG wrote on Apr 24th, 2012, 6:21am:loose-electron wrote on Apr 23rd, 2012, 8:14pm:This method gets used in GSM receivers for many years with the offset setting frozen for the TDMX cycle. (Adjust while transmitting, freeze setting while receiving.)
OK, I understand what you are doing now. I didn't realize you were holding the correction value since that hasn't been an option for me (excepting when you ping-pong between two zeroed amps). Yes, that would be probably be better if you have two different modes.
Like I said - you can
also do it in a continuous mode ,
as long as the feedback offset steps are a small amount of the received signal.
I don't see what the problem is visualizing this.
This stuff is old news you don't see it in IEEE JSSC
publications, because its been around so long.
