RobG wrote on Apr 23rd, 2012, 9:05am:I'm not sure a digital solution is going to be smaller than just using a big cap. It will also introduce it's own ripple that will have to be filtered. Depending on the desired accuracy, I expect you will need an anti-aliasing filter in the FB path, but I don't think that would be much of a problem. [edit, I see Jerry speaks of a digital counting method to avoid the analog LPF, so the output may not need to be filtered, and the aliasing might average out, except for the components aliased to DC. But I'm not sure I completely understand how to realize that digital solution.]
Yikes. The area taken by an integration capacitor will be huge.
This method gets used in GSM receivers for many years with the offset setting frozen for the TDMX cycle. (Adjust while transmitting, freeze setting while receiving.)
It also gets used to cancel offset in WCDMA receivers. (dynamic adjustment all the time)
Those are the two that I have done.
The magnitude of the LSB summing into the feedback point is a small amount of the signal, so that the feedback system provides small incremental adjustments.
Suggestion if you are having trouble visualizing this.
Start with an analog feedback model, start bring pieces of into the Z domain. When you get done, you can get it down to a comparator on the output and a summation DAC at the input. Everything else is logic. Less space, less power.
