mtp3
Hi!
I am pretty new to the AMS setup and all so please bear with me. I am trying to setup a work environment for a mixed signal simulation. When I use a verilog description of the a block every thing works fine, but when I try to use a standard cell from the PDK (STM) in this case I get errors during design ellaboration. The exact error is
ncelab: *E,CUCFUN: instance 'U78' of the unit 'HS65_GL_IVX9' is unresolved in 'PllDco.fractional_logic:functional'.
I have extracted the standard cell library using the setup.ncverilog script in to an inca.lnxxxxx.pak file but I don't know how to include it in the simultion or use it.
Can someone please guide me how to solve this issue. I am using AMS from the config view in cadence IC6.15.
