varun patial
hello all I am doing calibre pex in cadence working enviornment bt while doing inductance extraction following errror is coming ERROR: SVRF layer physical information could not be built. ERROR:The inputs for the inductance engine were not properly built. I surf the net regarding the problem wht i extract is 1. is that i have t convert metal1 drawing txt layer to M1 label layer 2. needed to use a TEXT LAYER textL statement . But I have no idea which one will quantify the problem and how to use 1 and 2
