Jan 20th, 2026, 4:43am
Calibre PEX issues (Read 2688 times)
varun patial
Calibre PEX issues
May 17th, 2012, 11:36am
hello all
I am doing calibre pex in cadence working enviornment bt while doing inductance extraction following errror is coming
ERROR: SVRF layer physical information could not be built.
ERROR:The inputs for the inductance engine were not properly built.
I surf the net regarding the problem wht i extract is
1. is that i have t convert metal1 drawing txt layer to M1 label layer
2. needed to use a TEXT LAYER textL statement .
But I have no idea which one will quantify the problem and how to use 1 and 2
« Last Edit: May 18th, 2012, 12:09am by varun patial »
