May 19th, 2024, 5:14am
Simulation & Modeling of non linear magnetics (Read 12383 times)
jerome_ams
Jul 06th, 2012, 2:12am
Hi there,
I am using the core and winding verilog-a models provided on www.designers-guide.org as a starting point to model and simulate a flyback transformer topology.
Here the circuit:
Here are the waveforms I would expect:
But I do not get these waveforms out of the simulation. Indeed as soon as the current is turned off at the primary side the flux collapses very quickly and no current is available at the secondary side.
The model does not seem to feature any magnetic energy storage.
Has anyone some more experience simulating this model/application?
Great thx!
jerome_ams
Re: Simulation & Modeling of non linear magnetics
Reply #1 - Jul 6th, 2012, 2:14am
here the circuit (new try):
Reply #2 - Jul 6th, 2012, 12:36pm
jerome_ams wrote on Jul 6th, 2012, 2:12am:
Hi there,
It took me a few clicks to find these models:
http://www.designers-guide.org/Modeling/jilath.va
Are these what you are using?
jerome_ams
Reply #3 - Jul 10th, 2012, 1:07am
Yes, exactly
jerome_ams
Reply #4 - Jul 23rd, 2012, 2:26am
so nobody has ever tried these models in a flyback converter topology?
Reply #5 - Jul 23rd, 2012, 6:39am
I haven't tried these models (in any simulation).
Did you try the netlist in the associated whitepaper?
http://www.designers-guide.org/Modeling/mag.pdf
jerome_ams
Reply #6 - Aug 3rd, 2012, 5:45am
We finally got the expected simulation results. Let me emphasize on it, to close this post:
Actually, while connecting properly the windings, the gap and the core and using a diode on the secondary side to block this side when the primary is energized, the expected simulation results were obtained.
Real problems started when the testbench was slightly changed to fit to our very application: no diode is used on the secondary side, but an analogue switch. When switching the primaty OFF and the secondary ON, a peak current was observed on the secondary current instead of the expected "triangle". Replacing the switch by a trivial Dmos VHDL-AMS model solved this issue!
At a first glance it feels like changing the resistance of the switch from Roff to Ron using a digital signal as a trigger did not give the same results as changing the resistance of the diode fom Roff to Ron using the voltage drop at the diode as a trigger... Timig issue? => we are still investigating this testcase...
Cheers,
J
Reply #7 - Aug 13th, 2012, 5:46am
Thanks for letting us know how you got success.
