Verilog-AMS
Analysis
Modeling
Design
Theory
Welcome, Guest. Please
Login
or
Register.
Please follow the Forum
guidelines
Aug 3
rd
, 2024, 11:19pm
Home
Help
Search
Login
Register
PM to admin
Design
Analog Design
› regulator & PLL/DLL transfer function or bandwidth
Previous topic
Next topic
regulator & PLL/DLL transfer function or bandwidth (Read 660 times)
supermoment
Jul 09
th
, 2012, 7:26pm
hi
If the PLL/DLL close-loop bandwidth is 5MHz, does it mandate a wideband voltage regulator (good PSRR for wideband). Could the voltage regulator PSRR freq be relaxed since the PLL/DLL loop bandwidth is 5MHz.
IP Logged
supermoment
Re: regulator & PLL/DLL transfer function or bandwidth
Reply #1 -
Jul 17
th
, 2012, 12:53am
hmm.. the power noise transfer function in PLL/DLL is high-pass. can i say that it requires voltage regulator with good PSRR for wideband freq?
IP Logged
BackerShu
Reply #2 -
Jul 18
th
, 2012, 8:55pm
Not exactly, for regulating VCO in a PLL/DLL, TF from regulator input to output, and TF from regulator output to VCO output (usually it's a bandpass TF) should be considered together. Usually, an optimal design would achieved by misaligning peaks of two TFs.
These two papers would be good references for this:
http://ieeexplore.ieee.org/xpls/abs_all.jsp?arnumber=5173751&tag=1
http://ieeexplore.ieee.org/xpls/abs_all.jsp?arnumber=5518351
Thanks and Regards!
BackerShu
https://www.linkedin.com/pub/shu-guanghua/26/b72/711
IP Logged
supermoment
Reply #3 -
Jul 18
th
, 2012, 10:24pm
thank you very much
i will take a look on these papers
IP Logged
Previous topic
Next topic
Forum Jump »
» 10 most recent Posts
» 10 most recent Topics
Design
- RF Design
»» Analog Design
- Mixed-Signal Design
- High-Speed I/O Design
- High-Power Design
- Mixed-Technology Design
Analog Verification
Measurements
- RF Measurements
- Other Measurements
Modeling
- Semiconductor Devices
- Passive Devices
- Behavioral Models
Design Languages
- Verilog-AMS
- VHDL-AMS
Simulators
- Circuit Simulators
- RF Simulators
- AMS Simulators
- Timing Simulators
- System Simulators
- Logic Simulators
Other CAD Tools
- Entry Tools
- Unmet Needs in Analog CAD
General
- Tech Talk
- News
- Comments and Suggestions
- Opportunities
« Home
‹ Board
» Powered by
YaBB 2.2.2
YaBB
Copyright 2002-2024
Designer’s Guide
All rights reserved.
Send comments or questions to
editor@designers-guide.org
. Consider
submitting
a paper or model.
