May 19th, 2024, 3:47am
real number model with Systemverilog (Read 515 times)
rampat
Jul 25th, 2012, 9:36pm
Hi
I am trying to model bias current port using real number model as below
output real ibias[8:0];
In my testbench where I am instantiating this module I have defined
real ibias[8:0] , but the issue is ncverilog is showing error when I pass this variable  as
.ibias(ibias[8:0])
error message : Part-select ot indexed part-select cannot be applied to memory [4.2.2(IEEE)].
Does this mean that i can not pass variable bus as port ?
View Profile rampat   IP Logged
