radius2
Hi
I'm trying to create an instance with a parametrized bus in Verilog-A i. e. when I instantiate it in a schematic in cadence, then there should be a parameter to determine the size of the bus by clicking on the instance and pressing Q. The idea is to avoid creating several instances with the same functionality but with different bus sizes. However, I'm wondering if this is possible. What would happend with the bus pin when the symbol is created?
I've come across a few ways that give some clues for example:
module adc(out, in, clk); . . parameter integer bits = 8; // resolution (bits) . . output [0:bits-1] out; electrical [0:bits-1] out;
This however generated the following error: "Encountered missmatch in size of formal and actual for out, make sure the size of formal and actual match"
Another example I found, used the line `define bits 8 before the line module adc(out, in, clk);, instead of defining bits as a parameter. However this doesn't include the possibility to change the bus size when putting the instance in the schematic.
So before I discard the idea completely I wanted to ask here if this is possible to do.
