May 6th, 2024, 7:11am
setting  parameters  in verilogams to vary with corners (Read 2634 times)
sammy_bee
Feb 6th, 2013, 9:39am
Hi All ,
I m  new to verilogams.  My verilogams module works fine with  norminal  model. Now i want to vary a  parameter based on the digital corner being used my the simulator. For instance if the simulator is using strong models  , I want to set  parameter P = 1 and if it is using weak models , set P =2 .Can any of you provide me with help on how to do this?
« Last Edit: Feb 07th, 2013, 7:27am by sammy_bee »
spinfab
Re: setting  parameters  in verilogams to vary with corners
Reply #1 - May 16th, 2013, 4:50am
The best way to do so, is to use a model card approach, i.e writing spectre netlist with 'model' statment.
fab
