Nov 8th, 2024, 8:51pm
Setting maxacfrequency for PSS/PXF analyses (Read 1515 times)
n2sinha
May 01st, 2013, 1:18am
I am trying to simulate a switched-cap filter response using PXF. I am sweeping the frequency from 0 to 2.5MHz (my fundamental freq is 5MHz) and using 40 sidebands to see the filter response till about 200MHz. As per the spectreRF manual, I set the maxacfrequency in PSS  to 500MHz [larger than (2.5M + 40*5M) = 202.5MHz] but I noticed that my filter response changes as I change this to 400MHz or 600MHz...
Can someone  please help me understand how I need to set this "maxacfrequency" parameter in PSS and if I am missing something?
Thanks a lot! Smiley
