Jul 16th, 2024, 4:50am
DPSK modulator (Read 5854 times)
sarge
Belarus
DPSK modulator
Jun 27th, 2013, 5:34am
Hi
I try to build DPSK binary modulator with using VerilogA.
Here my code:
`include "constants.vams"
`include "disciplines.vams"
module DPSKModulator(in, clk, out);
input in;
input clk;
output out;
electrical in;
electrical clk;
electrical out;
parameter real Amplitude = 0.2;
parameter real Freq = 4G;
parameter real vth = 0.6; //Threshold voltage
parameter real offset = 0;
real phase;
real Krand;
real Krandlast;
analog begin
@(initial_step) phase = 0;
@(cross(V(clk) - vth, +1))
begin //On rising edge clk
	if (V(in)>vth)
		phase = phase + `M_PI;
V(out) <+ Amplitude*sin(2*`M_PI*Freq*$abstime + phase)+offset;
Clock frequency is double data frequency.
It is works, but there are peaks on carrier frequency on spectrum:
In same time, i built bpsk modulator in manner like above and it is works fine.
In what could be the problem? How I can remove these peaks?
Re: DPSK modulator
Reply #1 - Jun 27th, 2013, 8:48am
In general you would have been better served if you also showed the time domain waveforms so we could look for unusual artifacts. However, you made two classic mistakes, and you will probably get better results if you fix those.
1. You are generating a sinusoid at a frequency that is much higher than any input frequency and yet you have no $bound_step function to prevent aliasing/Nyquist problems.
2. You are abruptly changing the phase and yet you have no transition function to control the transition times.
In addition, your initialization of phase to 0 is unnecessary, it defaults to 0.
You might try something like this:
input in; electrical in;
input in; electrical clk;
output out; electrical out;
real phase;
analog begin
	@(cross(V(clk) - vth, +1)) begin
		if (V(in) > vth)
	V(out) <+ Amplitude*sin(2*`M_PI*Freq*$abstime + transition(phase, 0, 1n))+offset;
	$bound_step(0.1/Freq);
sarge
Belarus
Re: DPSK modulator
Reply #2 - Jun 28th, 2013, 6:42am
Thanks for responce!
I tried to build it as you advised (but i changed transition time to 50ps, 1ns very big for 4GHz signal) and i got same pictures as above.
Here piece of transient waveforms:
