May 2nd, 2024, 7:56am
Understanding resistor usage (Read 4378 times)
GregS
Sep 10th, 2013, 12:21pm
Friends,
I'm new to Verilog-A/Verilog-AMS, and I've run into something that I can quite explain.  I've tried to setup a resistive load on an electrical input to my model, and I get an error from the simulator when I use one coding style over another.  The message looks like this:
FATAL: The following branches form a loop of rigid branches (shorts) when added to the circuit
I thought this code was equivalent, but obviously it's not, or I have an error somewhere else.
Coding example #1:
Define a resistor model like this:
module res (PLUS, MINUS );
inout PLUS, MINUS;
electrical PLUS, MINUS;
parameter real r=1 exclude 0;
analog
 begin
   I(PLUS,MINUS) <+ V(PLUS,MINUS)/r;
Instantiate this reistor model in another model like this:
module blah (VDDIO, VSS);
inout VDDIO;
inout VSS;
electrical VDDIO;
electrical VSS;
real Ivddio;
res #(.r(10k)) load7 (.PLUS(VDDIO), .MINUS(VSS));
analog
 begin
    Ivddio = I(VDDIO,VSS); <--This creates an error during simulation
Coding example #2:
inout VDDIO;
inout VSS;
electrical VDDIO;
electrical VSS;
real Ivddio;
analog
 begin
    I(VDDIO,VSS) <+ V(VDDIO,VSS)/10k;
In the 2nd example, I'm not instantiating the resistor, I'm simply encoding the resistive load into the voltage to current relationship, and 2nd example operates like I expect, no errors and I can monitor my current through the resistive load in simulation  In the first example, if I code the line to monitor the current, the FATAL error occurs.  Any ideas why this is treated differently?  I must be missing something basic.
Thanks for your help.....
boe
Re: Understanding resistor usage
Reply #1 - Sep 12th, 2013, 4:32am
GregS,
The error shows you have shorted two (ideal) voltage sources (the other is probably in the testbench).
Because there is no branch between the nodes in ex. 1, the simulator has to add a source to measure the current (NB: an ideal amp meter is a short).
In ex. 1, you should measure the current through a port or from blah.VDDIO to blah.res.PLUS.
- B O E
