Jul 22nd, 2024, 10:15pm
how critical is the loop filter capacitor layout in a PLL? (Read 1887 times)
aaron_do
Sep 30th, 2013, 7:09pm
just wondering how critical is the loop filter capacitor's layout in a PLL? I was thinking to fill up some of my empty space in the layout with the loop filter capacitor. So it would be a little spread out.
thanks,
Aaron
tm123
Chicago, IL
Re: how critical is the loop filter capacitor layout in a PLL?
Reply #1 - Oct 1st, 2013, 11:26am
Aaron,
The only thing I can think of right now is make sure not to route the VCO control voltage line near anything that could couple to it and cause you spurious headaches.  So if one of the plates of the capacitor is connected to the control voltage line make sure you review all other routes around the cap.  No signal routing, clock routing, etc. should be near the cap.  I will post again if I think of anything else.
Tim
aaron_do
Reply #2 - Oct 1st, 2013, 5:40pm
Thanks for the advice.
Aaron
carlgrace
Berkeley, CA
Reply #3 - Dec 25th, 2013, 9:11pm
Tim gives good advice.  If your PLL depends on an accurate loop filter value it is a poor design.  That said, remember that the loop filter control voltage is the holy node for a PLL and needs to be protected at all costs.  I would run it from the charge pump to the filter cap on a high metal with a ground shield beneath it.  Also,  make sure your loop filter cap is shielded and make sure there is a guard ring (preferably double guard rings around it).
Remember that the absolute value of on-chip caps can vary by +/- 10 or 15% if you are using MIMs and more than 25% if you are using MOSCAPs.  Be sure you can trim your filter caps with register bits.
Reply #4 - Dec 31st, 2013, 10:58am
aaron_do wrote on Sep 30th, 2013, 7:09pm:
thanks,
Aaron
Great opportunity to couple noise into the VCO control voltage!
If jitter (or phase noise) is not important then go for it.
Invariably, the most noise sensitive node in any PLL-VCO is the node between the charge pump out and the VCO in.
Reply #5 - Dec 31st, 2013, 11:01am
carlgrace wrote on Dec 25th, 2013, 9:11pm:
Shield it with a ground where the ground is connected to the VCO reference ground, and only to that ground.
- no current in the ground shield
- ground on an IC is like a trampoline.
aaron_do
Reply #6 - Jan 2nd, 2014, 6:34pm
Thanks for all the help guys.
Just wondering, are you implying that the VCO ground should be separate from the rest of the PLL's ground?
thanks,
Aaron
Reply #7 - Jan 10th, 2014, 4:29pm
aaron_do wrote on Jan 2nd, 2014, 6:34pm:
thanks,
Aaron
Impossible to truly separate. You need to process everything differentially and try to optimize your local ground integrity.
However, if you are trying to shield a signal, you wish the shield to be referenced to the receiver's ground, and avoid currents in the ground shield.
That says the ground shield is connected to the receiver's ground only.
aaron_do
Reply #8 - Jan 12th, 2014, 4:53pm
thanks for the insight
Aaron
