aaron_do wrote on Jan 2nd, 2014, 6:34pm:Thanks for all the help guys.
Quote:Shield it with a ground where the ground is connected to the VCO reference ground, and only to that ground.
Just wondering, are you implying that the VCO ground should be separate from the rest of the PLL's ground?
thanks,
Aaron
Impossible to truly separate. You need to process everything differentially and try to optimize your local ground integrity.
However, if you are trying to shield a signal, you wish the shield to be referenced to the receiver's ground, and avoid currents in the ground shield.
That says the ground shield is connected to the receiver's ground only.
