Apr 27th, 2024, 3:35pm
Does spectreVerilog only support Verilog module with clk under 1GHz? (Read 4242 times)
Lynn Lou
Oct 04th, 2013, 2:33am
I was doing a RF/Digital-Mixed simulation, in which I employed a counter to evaluate the divided RF signal. However, I found the counter gives a wrong value. At first, I thought the verilog code of the counter maybe has some faults. Eventually, when I lower the input signal frequency to 0.9GHz, the counter output the right value.
Does the spectreVerilog only support the clk of the digital module under, say, 1GHz?
Thanks.
Lynn Lou
Re: Does spectreVerilog only support Verilog module with clk under 1GHz?
Reply #1 - Oct 8th, 2013, 5:12am
Hi everyone,
I found the Verilog-XL (which is employed by spectreVerilog ) exhibits a default delay of 1ns. That's maybe the reason why the counter just output no more than 500MHz freqency.
There must be options to change the default delay(i.e. 1ns) somewhere. Could anyone give me a hint, please?
Thanks a lot!
Lynn Lou
Reply #2 - Oct 8th, 2013, 5:59am
I just set the "Global Sim Time" and "Global Sim Precision" from 1ns(default) to 1ps, and the problem solved. The two parameters are under ADE: "Setup"->"Environment" ->" Verilog Netlist Option".
Thank you all Smiley
